ls1 ls2 difference
Old Dec 11, 2008 | 02:39 PM
2kredss's Avatar
Default ls1 ls2 difference
i'm using an ls2 block on my turbo build in my ls1 car and i'v heard there are parts that are not the same, what is different????
Old Dec 11, 2008 | 02:47 PM
FiFdYnUtz's Avatar
im sure you know this but the ls2 block itself is a 6.0L if that helps lol
Old Dec 11, 2008 | 03:29 PM
12secSS's Avatar
These are the main differences between the two (short) blocks:
LS1 (CID = 346, 5.7L)
3.89" bore
Knock Sensors in lifter valley
Cam sensor located at the top, back of the block, next to the oil pressure sender
LS2 (CID = 364, 6.0L)
4.00" bore
Knock Sensor located on either side of the block, externally between 3-5 and 4-6
Cam sensor is located on the front cover
