double roller install Q.....
Old Sep 26, 2003 | 09:38 PM
SSactionLs1's Avatar
Default double roller install Q.....
just to make sure...i put on a rollmaster double chain... and the dot on the END of the crank sprocket goes where the nipple is on the crank right? and the OTHER dot by the actual chain goes aligned with the cam dot correct?
Old Sep 26, 2003 | 11:27 PM
Inspector12's Avatar
TT-TECH Veteran
Default Re: double roller install Q.....
Well when you install the lower gear on the end of the crank if you want to install it strait up (with out adding any advance) you put the dot on that key way and then the cam gear's dot at the bottom closest to the crank gear. In other the dots will be facing each other this is of course if your motor is at TDC Top Dead Center. You know you could just got to Ls1 How to and check out a great write up by JMX. Hope that helps you make sure you check it twice!
