P&P stock heads question
Get with PerdatorZ or PatrickG and have them Spec you a custom grind for your setup. will cost the same as a new cam either way.
TSP 5.3L stage 2.5 heads with a TSP 228R will get you over 400hp and run $1700. for the H/C combo
But, to do it right get the BEST heads you can afford with a custom cam.
the key to POWER is the RIGHT combo for what you want!
