228R or Torquer v.3
Old Dec 16, 2008 | 09:08 PM
WALK NASTY984's Avatar
Default 228R or Torquer v.3
wanting to know which cam will be the best for the street....car is only raced from a roll 20-100.....just seems like the wide powerband on the 228r would benefit more!!!
Old Dec 17, 2008 | 09:32 AM
teke184's Avatar
with the right gears the T3 would be pretty nasty
but for overall street use...i'd stay with the 228r
Old Dec 17, 2008 | 09:49 AM
Dragkid1917's Avatar
You should call texas-speed. I called them multiple times and talked to them about all of there cam's. I personally dont like the huge intake on a v.3 however, i do know it makes more horsepower. What i would do is go with a v.2 (232/234 - .598/.598) or a 233/239 cam witch makes even more horsepower (233/239 - .595/.603). The 228 cam, while good (228/228 - .588/.588), doesnt make as much power as the others, and as you can see, theres not a huge difference between the 228 and the v.2, and the v.2 will make more power. The v.3's specs are 231/234 - .643/.598.
Old Dec 17, 2008 | 10:11 AM
JosephIV's Avatar
^^^^Good Advice. I talked to TSP over the phone and am happy with my choice. I went with a TQR V2 which comes alive after 3k RPM. Give them a call, they are very friendly to deal with and can easily explain what lift, duration, and LCA would work best for you and why.
Old Dec 17, 2008 | 12:11 PM
Kingc8r's Avatar
For sure, they are patient and will walk you through your choices to help you make the right decision
Old Dec 17, 2008 | 02:57 PM
HSVGTS300's Avatar
i have the 228R and must say i'm very happy with it.300rwkw and 504nm in an M6.Not too many other mods - dual 3" cat back, Mafless tune with 4"intake pipe with BMC pod filter.
Old Dec 17, 2008 | 05:25 PM
ABQ99TA's Avatar
I think calling TSP is a good idea. I have the TV3 and love it, my buddy runs the 228r and he likes it also but wishes he would have gone with the TV3 instead, because my car pulls his better than we expected. I think they are both good cams so give TSP a call and they will hook you up.
Old Dec 17, 2008 | 05:40 PM
Hi-Po's Avatar
I just talked to TSP last night and they seem to think a LQ4 with 5.3 heads with a T V.2 will have PTV issues. I do not know if the heads were milled or not, thats my problem. Or if they have the larger valves. My heads are the Lingenfelter 5.3's. I was all set to buy the V.2 last night but now I am stuck.
Old Dec 17, 2008 | 05:50 PM
danger ds's Avatar
You can never go wrong with the 228R cam. Good street manners, easy to tune, and most of all a consistent performer.
