Running Leaded gas
Old Sep 28, 2003 | 09:20 AM
solidz06's Avatar
Default Running Leaded gas
Hey guys,
What is the easiest way to run leaded gas. I need to run 116. I have seen a few ideas. They have been to run in open loopwith no o2's. Or buy Bosch Lead tolerant O2s. I basically live in a a area where the climate is the same all year. I like the idea of using a wideband for tuning and then forget about the o2's. Any comments would really help. Also can we run in closed loop fulltime(open loop-I get them confused,whatever loop that the com does not read o2's. And can closed loop operation be tuned.
Thanks
Randy
Old Sep 28, 2003 | 12:11 PM
solidz06's Avatar
Default Re: Running Leaded gas
common guy's. Any thoughts
Old Sep 28, 2003 | 12:17 PM
2000RATA's Avatar
Yes. VP, as well as otheres, makes a fuel that is for fuel injected use with O2 sensors. It's not 116 octane but unless you are running 14:1 compression at sea level, you will not need 116 octane. More octane than you need will lose power. The fuel I'm referring to is rated around 105 octane. I can't remember exactly. It would support an easy 12:1 compression ratio.
Old Sep 28, 2003 | 04:57 PM
solidz06's Avatar
Thanks for idea. Sunoco Unleaded Gt which is 104 is to little. Ya. I'm going to be 14-14.5 to 1.
Solid roller 427
Randy
Old Sep 28, 2003 | 05:57 PM
gator's 99TA's Avatar
why are you going with such a high compression motor? that is way way high. HP can be made without that high compression
Old Sep 28, 2003 | 08:09 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd look into an open loop tune or maybe try those Denso 02's but they might not last real long.
PSJ
