WTF is wrong with my motor?
Old Dec 19, 2008 | 01:43 AM
Hemi Killer's Avatar
14 Second Truck Club
Default WTF is wrong with my motor?
Half the time it will crank, half the time it won't. Sometimes I can start it and it will idle rough for a few seconds and find idle. Sometimes it takes 3-4 times of turning it over before it will crank, all this happens when it's cold or has been running.
If I don't let it warm up for at least 15-20 minutes, I back out of the driveway and it bucks and revs, sometimes goes dead in reverse every now and then. Or when I get to the stop sign, it bucks and revs and goes dead either at the stop sign or turning at the stop sign.
Even when I let it warm up, it still surges slightly when coming to a stop and at sharp turns after a stop. Then I can go to the store or get some food, get in and have to turn it over 3-4 times.
-I haven't felt any power loss. It still pulls hard as hell at WOT.
-When I had it dyno-tuned last year, it never did any of this, the tune and drivability was perfect (Props to Allan!)
-I've checked for vaccum leaks, can't find anything.
-I've done the idle relearn twice and nothing.
-Fuel pump whines constantly (I'm thinking it's something to do with the pump)
Has anybody ever had this crap? Or know what it might could be? Because it seems to be getting slightly worse over time...
Old Dec 19, 2008 | 01:45 AM
cabech984's Avatar
Could one(or more) of your sensors be going out? perhaps a cam or crank sensor??
Old Dec 19, 2008 | 01:48 AM
I don't know, the SES light hasn't came on while it's been doing this. Wouldn't it come on if it was a sensor? Thanks
Old Dec 19, 2008 | 07:24 AM
cam75w/ls1's Avatar
I would scan it anyway. Sometimes the computer logs codes in memory w/o turning on the light.
Old Dec 19, 2008 | 08:39 AM
teke184's Avatar
have you checked your fuel pressure? since you say the pump makes noise.
could be its intermitantly losing pressure.
pretty easy check.
and if you unplug the MAF, doesn't it go into "limp home mode"? if it runs better in that mode it tells you a sensor is going out...right?
Old Dec 19, 2008 | 01:41 PM
5.3LJimmy's Avatar
It could very well be inconsistent fuel pressure. The difference in pressure will reek havoc on the fuel trims and cause poor driveability. Try to get your hands on a fuel pressure gauge that you can hook up and tape to the windshield so you can monitor it while driving. Have you replaced the fuel filter lately?
Old Dec 19, 2008 | 07:32 PM
Shawn MacAnanny's Avatar
I would say unplug your MAF and see if it drive better. Yes it throws a check engine code and puts the engine in limp mode but it will run fine without the MAF, you wont even notice. You'll just hear the fans running constantly.
Old Jan 1, 2009 | 02:09 PM
Could an exhuast leak cause this? Like before the first O2 sensor?
Old Jan 4, 2009 | 12:02 AM
domestic disturbance's Avatar
My buddy was having about the same problem with his lt1 car... factored out the fuel pump and all at first becuase we could here it running... so checked everything else out and everything looked fine, decided to check the fuel pressure, it had no fuel pressure, pulled the line of by the fuel filter, the fuel pump was not pumping no fuel but yet seemed to sound fine... pulled it out put power to it in a bowl of water and it operated ok but pumped nothing out, slapped a new fuel pump in and has not had a problem yet! Id def check your fuel pressure on your schrader valve since on the ls1 there verry easy to access....
Old Jan 4, 2009 | 03:55 AM
the_merv's Avatar
Check the Fuel Pressure and start from there.
Old Jan 23, 2009 | 07:54 AM
Fuel Pressure:
At Idle - 50psi
5000 - 44-45 psi
So it is my fuel pump, right? Isn't pressure supposed to increase with rpm or hold steady? I changed my fuel filter a few days before checking the pressure.
Old Jan 23, 2009 | 10:08 AM
SOMbitch's Avatar
Yes it your fuel pump. Supposed to be 58psi.
Old Jan 23, 2009 | 10:24 AM
GMCtrk's Avatar
consider yourself lucky it just didn't die. Mine gave no warning and died in the middle of the road
