Piston selection
Old Sep 28, 2003 | 10:30 AM
B-MAN's Avatar
Default Piston selection
What would be the best pistons to use.I am considering a 382 stroker with a little bit of juice.
all your opinnions matter good and bad experiences
Old Sep 28, 2003 | 02:58 PM
Noyzee's Avatar
8 second mod
Default Re: Piston selection
DIAMOND>>>>>>>>>>>>>>>>>>
Old Sep 28, 2003 | 05:08 PM
FSTR-THANU's Avatar
Outlaw 10.5 Director
Give Chris a call at Diamond! He will hook you up!
Tom
Old Sep 29, 2003 | 03:41 AM
blu00rdstr's Avatar
Whatever you pick, consider getting coated or having them coated. Apparently it makes a big difference in noise and helps reduce heat transfer to piston.
Old Sep 29, 2003 | 02:29 PM
robertbartsch's Avatar
If you want coated pistons, does this impact the diameter of the piston?
In other words, if you want coated pistons do you have to start with a smaller piston ....or is the coating only used on the top and skirts which does not increase the diameter of the piston?
