oil pump bolts
Old Dec 20, 2008 | 09:41 AM
camarorat's Avatar
Default oil pump bolts
Can anyone tell me the size of the Oil bump bolts and pivk up bolt. I am building a bare block and don't want to keep my current LS1 in tact to sell. I have some xtra cover bolts, oilpan bolts, are they the same? It seems like most of the bolts are the same on these engines.
Old Dec 20, 2008 | 09:51 AM
405HP_Z06's Avatar
Oil pump to block: 4 each - M8 x 1.25 x 28mm
Oil pump pickup tube: 1 each - M6 x 1.0 x 15mm
Oil pump plate to oil pump body: 7 each - M6 x 1.0 x 20mm
Old Dec 20, 2008 | 03:42 PM
camarorat's Avatar
Thanks, I guess the pump to block bolts would be the same as the valley cover bolts then.
Old Dec 20, 2008 | 03:53 PM
405HP_Z06's Avatar
I measured the stock valley cover bolts at M8 x 1.25 x 30, only two mm difference. I didn't measure the depth of the holes in the block so I can't absolutely say one would work for the other.
I replaced my oil pump to block bolts with ARP 6 point black oxide bolts and used 25mm instead of 30mm which was the next closest length.
