Priming Oil pump
Old Sep 29, 2003 | 07:13 PM
Smoke_Ford's Avatar
Default Priming Oil pump
I put the SLP ported oil pump on my car, what are the priming procedures for it? Any other tips before initial start?
Old Sep 29, 2003 | 08:07 PM
Smoke_Ford's Avatar
Default Re: Priming Oil pump
TTT
Old Sep 29, 2003 | 08:30 PM
TaTommyWS6's Avatar
Before installing the new pump, fill it with oil (in the pickup hole, on the gears, etc...) Give it a few turns by hand, and fill again...
Yeah it will spill out, but do your best to keep as much oil as possible in it while bolting it on.
That's it.
Tommy
Old Sep 30, 2003 | 02:37 AM
JxxxOxxxE's Avatar
After my cam and new pump install, I pulled my fuel pump fuse, and my spark plug wires, then turned the car over for 30 - 60 seconds in 10 - 15 second intervals. Hooked everything back up, fired it up and instantly had pressure
Old Sep 30, 2003 | 03:05 AM
Smoke_Ford's Avatar
Thank you, that sounds like the plan man.
Old Sep 30, 2003 | 09:52 PM
wrencher's Avatar
wrencher
Or you can get a pre-charge oil unit , just thread it into to oil switch location & it will pre-lube the whole system.
