BROKEN Blue stripe 918
Btw. what cam were you running with the 1.85 rockers?
Weren't you using the comp 206/212 .565/.572? If that lift was with the 1.7 rockers.. going to a 1.85 changed it to .613/.622!! If that's the case.. I can't belive you only broke one of them.. let me know on the cam, I'm very interested in this.
Thanks
Scott
I would have no problems running a 918 spring on any car I drove as long as it suited the application.
Edit: Eboggs, could this have anything to do with the boost you're running or does it not play a factor in this situation?
