Need Help on an engine noise
This has been verified on my mechanical gauge. Also whenever I let off the gas after going WOT a loud ticking occurs untill it gets back to idle RPM's and then eventually goes away. Im thinking the Oil pump o-ring is not seated correctly as we reused my stock one that had 70k miles on it. Does what I am describing sound like a pinched or miss seated pickup O-ring? Im thinking so however I just want some second opinions before I go tear assing into this thing again. Thanks for the help guys!
I intstalled the following when I did my cam and heads as well.
I have a brandnew TSP ported oil pump, Rollmaster double roller chain, New LS7 lifters, ls2 lifter trays, new cromoly 7.40 push rods.
the motor wasn't making the noise before, so I assumed that my lifters would not just all of a sudden go bad during a cam swap
Symptoms of a leaking O ring would be decent, but not great oil pressure, ticking noise at idle or lower rpm, but not at a higher rpm. Caused by pulling crankcase air instead of oil around the O ring seal.
I know you don't want to tear yours back down, but I think that is prob your problem as well
