vindicator?????
Old Dec 30, 2008 | 07:11 PM
Jonsz28's Avatar
Default vindicator?????
guys i have recently purchased the vindicator cam, i actually bought the cam off a friend of mine, i was a steal on the brand new cam... i hadnt planned on installing it in my ddriver but now im leaning toward the install, but i was just wondering if i went with a set of heads such as prc heads, would i have to flycutt the pistons by ne chance.. hope im not sounding to stupid butt im not exactly sure for this size cam.... n e info will help, thanks
Old Dec 30, 2008 | 09:02 PM
RJB01camaross's Avatar
The specs are 240/244 609in 596ex 112+4 or at least close to that. You could put stage 1 heads with stock valves and be ok, but stage 2 and aftermarket casting with bigger valves or milling would require you to flycutt
Old Dec 30, 2008 | 10:38 PM
98blueSScamaro's Avatar
go with stock 243's and stock gasket and you will fit. the stage 1 prc for sure no fly cutting. And it will make alot of power read my sig for #'s with this cam and stock ls6 long block.
Old Dec 31, 2008 | 05:29 PM
Jonsz28's Avatar
do you think this cam will be a good choice for a daily driver, or r there n e issues that i should be aware of....
Old Dec 31, 2008 | 05:47 PM
01SuperSport's Avatar
This is the cam I might go with in the future and I don't think there will be any problems for a daily driver. I'm sure it'll be really really loud since it's a big cam but if you don't mind then go for it.
Old Dec 31, 2008 | 08:08 PM
z28adiction's Avatar
i just bought a vindicator and will be putting it in this spring also.
