Got My Custom Cam Spec's Pat G from LS1tech has been helping me get a custom ground cam for my car and this is what I got back Very Happy :D Cam recommendation: (2002 F-body with stock 346 LS1 engine, 67cc stock heads, .054” gasket, LS6 intake, 78mm TB, M6, 4.11 gear, 1 3/4” long tube headers with no cats, 6600 rpm shift points, 6800 redline) 231/231 .617”/.617” 111LSA +4 advance (with 1.7 ratio rockers) Comp LSL/LSL lobes 13018R/13018R HR111LSA +4 advance (107 installed intake centerline) Cam Valve Events 0.006 0.050 0.200 Intake Duration - ID 281 231 154 13018R LSL lobe .617" Exhaust Duration - ED 281 231 154 13018R LSL lobe .617" Lobe Center Angle - LSA 111 111 111 Intake Centerline - ICL 107 107 107 Intake Valve opens - IVO 33.5 8.5 -30 BTDC (- indicates ATDC) Intake Valve closes - IVC 67.5 42.5 4 ABDC Exhaust Valve Opens - EVO 75.5 50.5 12 BBDC Exhaust Valve Closes - EVC 25.5 0.5 -38 ATDC (- indicates BTDC) Exhaust Centerline - ECL 115 115 115 Overlap 59 9 -68 degrees • Static/Dynamic Compression with new cam: 10.28:1, 8.02:1 • Recommended valve springs: Patriot Extreme duals with Ti retainers. • Recommended pushrod length: 7.450”. Now to know what size injector's I need(I was just thinking 42's...not to big and the duty cycle can be turned down), and to order my fuel pump, also find some pushrod's. I'm looking at the TR set, and also at the Comp Cam Chrome Moly's. I'm super stoked Very Happy |
That thing is going to run like a raped ape. I too am considering building a cam on the LSL lobes. I do know how hard they will be on springs so let me know what you think. You need to get an idle clip of that thing too, it's going to sound like a demon. |
hmm i like that alot i was looking at the torquer v3 but the .643 lift is killer. i wonder what a 231/234 .617/.617 would be like? |
I am eager to see how this performs, keep us updated. |
Nice, I would be curious comparing that to my XFI/XE-R grind "El Torro" (230/230 .612/.598 111+4 LSA) to see the effect of LSL lobes on the powerband. |
Originally Posted by PREDATOR-Z
(Post 10755495)
Nice, I would be curious comparing that to my XFI/XE-R grind "El Torro" (230/230 .612/.598 111+4 LSA) to see the effect of LSL lobes on the powerband. Chris |
isnt anything over .600 lift going to be in the "flycutting" zone? Probably a dumb question, sorry, but im just learning when it comes to the H/C stuff. |
Originally Posted by Bad Blue WS6
(Post 10755710)
with stock heads, you probably can get away with stock injectors. if nothing else some FMS 30# would work |
Originally Posted by teke184
(Post 10755923)
Nice looking cam, Pat specd me one just a little smaller 227/231 similar lift on LSL lobes 113+4. I believe TR is out of their pushrods, but they can get you the comp ones. TSP also has chromoly pushrods in that size. Good luck with it, post up some numbers and vids when its done. |
Originally Posted by Adam1982
(Post 10757001)
Should be a good choice keep us updated |
Originally Posted by Grn4fbody
(Post 10757039)
I checked the TSP site and I didn't see any that size. I believe I'm just gonna go with the comps |
again i would definitely check PTVC... you will most likely be around 0.06x for the intake...standard street driven clearance is 0.080 intake...dont assume it will fit |
Originally Posted by chrs1313
(Post 10757394)
(Post 10758793)
It's not like it Pat G's first set up, I completely trust his info. if anything cams get made wrong more often than you think...so go through the time of either having the cam doctored or degreeing it yourself in the car...if you dont wanna check PTVC dont, peace of mind IMO though... |
(Post 10755688)
Me too would be interesting to see...to the op you better check PTVC with that cam i know my 230/230 on 111+4 was .072 on the intake... Chris I've spec'd over 100 cams in the 230 at .050" range for cam-only applications and none have reported dangerous P to V clearance. Russell should be able to run this cam with confidence. :) |
What I needed to know Pat, thanks :D |
(Post 10762754)
What I needed to know Pat, thanks :D dot to dot doesn't necessarily mean it is at that. the .050 specs are generic and the grind will not be exactly at those figures. So it is always wise to degree and check PTVC. Not only will you know what is happening but also you'll benefit from the true valve events that Patrick laid out for ya. Paying attention to detail on install of cams ensures every ounce of power we so dearely seek is taken out of it. |
| All times are GMT -5. The time now is 11:25 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
