shorter pushrods?
Old Jan 4, 2009 | 07:52 PM
spray_goat's Avatar
Default shorter pushrods?
if i have my ls6 heads milled to 59cc do i need to switch from 7.4 to 7.35 pushrods? tr230 cam btw
Old Jan 5, 2009 | 11:04 AM
conan's Avatar
Chances are you will need shorter ones. Best thing to do is get a push rod length check tool and measure what you will need then order.
Old Jan 5, 2009 | 04:27 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
With a 59cc 5.3L head you'd be close to being able to use a 7.400" pushrod in some cases...but for an LS6 head milled to 59cc, I'd bet you'll need closer to 7.350". Like stated above, the only way to do it right, is to check it with the proper tool.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
By Brett Foote | 2026-06-04 05:00:17
