What are the symptoms of running lean guys?
it's seemed to only miss 2 or 3 times like this in the past few days when under load... seems to be running fine as of now. But I'm not gonna drive it anymore till I can figure out what's going on.
I could just be paranoid as usual, but want to make sure before I go out and damage anything... hopefully nothing is damaged already...
Maybe you have detonation, bad gas, clogged fuel injectors or filter.
Best investment you will ever make. The causes of a backfire can be many, but why gamble with running lean. One or two detonations from running excessively lean will cost you more than the price of a wideband.
Hope it works out.
..WeathermanShawn..
