I need some help
I'm in the midst of a total rebuild on my engine and I need a new cam. Previously I had a tsp torquer v3 and loved it but the high lift mixed with hard use killed one of my valve springs. I've been hearing about a xfi/xer cam lobe combo. Is there any special set of springs that I would need? As far as power goes, what size cam would I need to put it on equal footing as the v3? Thanks in advance.
Ben
Ben
Well the only similar power your gonna get is with a custom grind cam..I would stick with what works (T2 T3), and for sure use Comp Cams Beehive with that setup..I heard Patriot duals are kinda stiff, so if your revving very high, failure is unavoidable..Hope that helps
