ms4 and valve relief cuts
Old Jan 9, 2009 | 02:13 PM
trav00ws6's Avatar
Default ms4 and valve relief cuts
i have talked to a couple of people. some say cut and others who have had the cam say they didnt have to. tsp said i will need them...
im getting a ms4 with a pair of ported l26 heads that have not been milled.
what head gasket and push rods do i need? what rocker ratio would be best?
Old Jan 9, 2009 | 02:52 PM
5.3LJimmy's Avatar
Is that ported LS6 heads with stock valves or larger than stock?
Old Jan 9, 2009 | 03:52 PM
ss.slp.ls1's Avatar
I would stick to the 1.7 ratio.
I would assume that stock LS1 gaskets would work.
As always, you should use an adjustable pushrod to verify your pushrod length.
Old Jan 9, 2009 | 04:25 PM
trav00ws6's Avatar
yes, stock valved heads
Old Jan 9, 2009 | 04:28 PM
lemons12's Avatar
if they are stock valves you should be ok...
im running ms4 and the prcls6 stg1s..
Old Jan 9, 2009 | 05:06 PM
trav00ws6's Avatar
i mean, i will check, just wanted to make sure.
