Need some help
Old Jan 9, 2009 | 06:03 PM
2000Z28ls1's Avatar
Default Need some help
I am putting in a new clutch and pilot bearing and the pilot bearing would not come out. So we did hte greese method, a slide hammer, finally had to cut it out in sections, I guess in the process knocked the oil plug on the crank out and now I have it here in my hand, what do I have to do to replace that?
Old Jan 9, 2009 | 07:39 PM
massls1guy's Avatar
you should read over in the manual transmission room, it's been covered over there:
https://ls1tech.com/forums/manual-transmission-14/
Old Jan 9, 2009 | 08:16 PM
jomomma's Avatar
is it broke? if so , id go to the dealership
Old Jan 9, 2009 | 09:39 PM
massls1guy's Avatar
No, not worth going to the dealer at all. It's not a big deal to get a new one and put it in.
Old Jan 11, 2009 | 10:24 AM
2000Z28ls1's Avatar
There any special installation techniches? I bought a couple freeze plugs and some gasket maker from Advanced, gonna get get something that is around its diameter and press it in with alittle gasket maker around the edges.
Old Jan 11, 2009 | 12:18 PM
massls1guy's Avatar
To clarify my post #4 above - I would buy the plug from the dealer but don't have the dealer install it. If the one you got from advanced looks identical you're probably fine.
There are some threads over in the manual trans room. Here's a good one that talks about installing it, see post#3. Two videos there as well:
https://ls1tech.com/forums/manual-tr...-oil-leak.html
Old Jan 11, 2009 | 02:17 PM
hawk18's Avatar
Default + 1
+ 1+1+1
