trick flow or afr heads
Old Jan 21, 2009 | 04:44 AM
  #41
JL ws-6's Avatar
Race your car!
No I understand. I'm sorry you had a problem, if it was a wide spread issue I'm sure that it would be all over this board, hell would have been for a while but this is the first I have heard of it like I said.
I hope it works out, they're a damn good head.
Old Jan 21, 2009 | 07:03 AM
  #42
Abdullah's Avatar
Originally Posted by bboyxclub
Are the adjustable worth the money if you go with let's say the Vindicator or any other big cam?? Why??
i choosed the non adjustable Yella Terra roller rockers becuase i will not need to adjust them. i'm not sure what are the advantages of adjustable roller rockers over non adjustable rockers, some one might chime in and help.
Old Jan 21, 2009 | 08:57 AM
  #43
MAD_RACING's Avatar
Well, if you use Comp Cam R lifters there a must in order to set proper preload. Other than that I don't think it's necessary.
Regarding 875-16
All Pro Magnum Lifters™ require an adjustable valve train for proper operation.
http://www.compcams.com/Technical/In.../COMP4-115.pdf
Old Jan 21, 2009 | 01:45 PM
  #44
56chevyboy's Avatar
does anyone know how to make my post into a poll. i would like votes to make my decision. afr and tfs are both close and im sure et will catch up
Old Jan 21, 2009 | 02:40 PM
  #45
03_SS_22's Avatar
from those two i would go tfs all the way
Old Jan 21, 2009 | 06:24 PM
  #46
bboyxclub's Avatar
Yes please anyone chime in?? Thanks
Old Jan 21, 2009 | 07:21 PM
  #47
DrkPhx's Avatar
Originally Posted by macca33
Yes, done and done mate - still no joy. Fraser at speedinc - the vendor - is trying to get the problem sorted out. I certainly do not want to chuck $US2.5 k away - that is for sure.
Cheers
That sucks. Hopefully it's resolved to your satisfaction.
No doubt the Trick Flow heads are solid performers. I chose AFR when I first put together my current setup. I like the fact I can use the stock rockers and they flat out work at the track. Service is important to me and that is one area AFR really shines. They make a quality product and stand behind it 100%. Of course it's alway nice to have Tony here supporting his product.
