Stuck on cam swap, help please
Old Jan 17, 2009 | 04:24 PM
1998Z28LOADED's Avatar
Default Stuck on cam swap, help please
Hi guys thanks for stopping in. I'm putting in a cam on my 98 Z28 A4. The problem is I rounded off the fitting on the tranny cooler line trying to remove it from the bottom of the radiator. I noticed a gap in the hard line where it is rubber hose. Would my best bet be just to cut the hose to get the radiator out for now and buy a new piece of hose?
Old Jan 17, 2009 | 04:39 PM
l92's Avatar
l92
if it were me i would try a pair of vice grips on it and that don't work i would cut hose alot easier to work on it on the table
Old Jan 17, 2009 | 04:45 PM
I tried, it's basically fallng apart. I was wondering if the small section of black hose is easily replacable?
Old Jan 17, 2009 | 06:04 PM
DaddySS's Avatar
The lower hose is the pressure side and manufactured piece, so patching it is not so simple. Part #10278608 and it's only $20 for the complete assembly from GM. That's the way I'd go.
