P0303 cylinder 3 misfire code
Old Jan 20, 2009 | 10:09 AM
Pulse_GTO's Avatar
Default P0303 cylinder 3 misfire code
The car is a stock 2001 Z28 with an SLP lid. The car owner changed plugs to TR6 so that he could run a shot of nitrous. As soon as he completed the plug swap the car started to misfire. We swapped plugs back, got new wires, swapped coils around, pulled the valve cover and the springs and rockers looked fine. It only misfires at idle, while driving under a load there are 0 misfires in the HPTuners scanner. What could this be???
Old Jan 22, 2009 | 12:42 PM
Pulse_GTO's Avatar
The owner figured out what it was. He cross threaded the plug causing it to not seat completely. He wrapped the plug with Teflon tape to test the theory out, and the misfires went away.
Old Jan 22, 2009 | 01:22 PM
ss.slp.ls1's Avatar
That sucks, hopefully he doesn't blow it out. I blew out a spark plug after a shop crossthreaded one of my spark plugs. It started as a faint ticking noise, then a week later...bang bang bang and a cylinder 7 missfire.
