Broken valve seat!! What are the odds?
Is it the valve guide??
Did you check for piston to valve clearance when you put the cam in?
Did you check retainer to guide clearance?
Did you put the correct springs on?
If it's the guides that are broken, it's likely the retainers hit the top of them, and broke some pieces off.
As for the pieces.. could be in the lifter valley, the pan.. Time to pull it down, and find the trash.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
