block machine work...
Anything over 383 & your at least lookin at a LS2 block set-up.
REMOVE THE F'ING CAM BEARINGS. After all the machine work is done, debris can get trapped behind the cam bearings and cause a really bad day once the motor is fired up.
Deck surfaces are gonne get cut to set the proper quench as well. Obviously, the cylinders get honed as well. Boring is only done to take out a lot of material, so that's not gonna happen to go from 3.898" to 3.905".
