Part number
Old Feb 4, 2009 | 06:02 PM
uLs1a's Avatar
Default Part number
Does anyone have the part numbers for the head gaskets and head bolts for a '98 Camaro Z28?
Old Feb 4, 2009 | 09:00 PM
JPH's Avatar
JPH
Use ARP #134-3609 head bolts and I use a '02 LS1 head gasket.
Old Feb 5, 2009 | 07:41 AM
zman1969's Avatar
Default bolts and gaskets
I agree the ARP headbolts are reuseable - they are NOT Torque to yield bolts and the later head gaskets are MLS or multilayered steel the original were graphite coated and are a pain to clean off the decks part# 12498544 are $29 a pair at Scoggin Dickey IMO a good deal i used them on my LS6 build
"This head gasket kit for 2002 and newer LS1 / LS6 engines from GM Performance Parts contains a pair of cylinder head gaskets.
New design steel shim gasket for 5.7L engines. Each gasket is interchangable and will fit either side. Approximate compressed thickness is 0.060""
good luck
