Dyno graph 439.9 UNTUNED
Old Oct 9, 2003 | 10:58 AM
Phil99vette's Avatar
7 Second Club
Default Dyno graph 439.9 UNTUNED
I was trying to add this to my corvetteforum web site but its down for some reason. If you copy and paste in a new window you can see it. If I remember correctly if you click to a geocities page it wont come up. I have the graph on my work computer and just need either a host or corvetteforum.com home pages to come back online. The car had valve float over 6100rpm. If the curve continues I think 459rwhp is very possible. The injectors were stuck wide open and there was no way to richen the program, I pulled timing back to 26/7 degrees to be safe.
Max HP UNTUNED 439.9 || 408rwtq. The program was richened 20% and yeilded 443rwhp but the A/F was roughly the same. SUPER LEAN.
27 degrees of timing
13 - 15:1 A/F
Copy and Paste: http://www.geocities.com/phillip_eclipse/Pa070063.jpg
Actualapproximated)
5250 - 400
5400 - 408 +8
5600 - 416 +8
5800 - 427 +8
6000 - 432 +5
6200 - 439 +7
6400 - 445 +6 predicted
6600 - 450 +5 predicted
6800 - 454 +4 predicted
7000 - 457 +3 predicted
7200 - 459 +2 predicted Cam Peak
Phillip
Old Oct 9, 2003 | 11:12 AM
gomer's Avatar
Default Re: Dyno graph 439.9 UNTUNED
I remember reading your cam specs somewhere before.. but can you post them in this thread for me?
Old Oct 9, 2003 | 11:14 AM
7 Second Club
232/238 XER 112lsa
Heads flowed 314cfm @ .600 && 225cfm @ .600
Old Oct 9, 2003 | 11:20 AM
gomer's Avatar
232/238 XER 112lsa
My 231/237 112 lsa peaked at 6300. What would make your cam peak so much higher? Also, what is the lift on it. Thanks for the info.
Old Oct 9, 2003 | 11:21 AM
7 Second Club
Does your cam have any advance ground in? .595/.605 lift My cam is ground straight up which will make it peak higher than cams with 4 degrees ground in.
Phillip
Old Oct 9, 2003 | 11:26 AM
gomer's Avatar
Ok, that makes sense. I'm pretty sure the TSP cam has 2 degrees ground into it.. I had it written down somewhere.
Old Oct 9, 2003 | 11:29 AM
7 Second Club
Can anyone host it? Looks like CF is going to be down for a while....
Phillip
Old Oct 9, 2003 | 11:30 AM
VINCE's Avatar
Shorty Director
My cam peaks at 6600rpm and I have 4 degrees of advance built in.. 232/236 lsa 114 +4..
Old Oct 9, 2003 | 11:36 AM
TEA Brent's Avatar
Phill, great numbers man. Vince you cam peaks a bit higher because of the 114 lsa. So phil you still are running into valve float, man that thing is gonna scream once you get it worked out. Keep us updated.
Brent
Old Oct 9, 2003 | 11:42 AM
7 Second Club
I just recently went to 977 springs, Comp R lifters and shimmed Yella Terra Rockers. Before @ 6200 you could fell the power fall off....now it pulls like a freight train to 7200 limiter.
Phillip
Old Oct 9, 2003 | 01:46 PM
jfm's Avatar
jfm
I would not be surprised if you get 460,good luck with your set up.
Old Oct 9, 2003 | 01:53 PM
7 Second Club
JFM,
THanks for the positive thoughts....I am adding a few things.....
Mezerie Electric Water Pump +10rwhp - 12rwhp
#42 injectors
Timing +2 - 7rwhp
DRE rockers +2 - 4rwhp
LSX intake +10 - 25rwhp
Fuel Tuning +2 - 7rwhp
Phillip
Old Oct 9, 2003 | 02:54 PM
7 Second Club
Can anyone host the graph? I have one that is enlarged...
Phillip
Old Oct 9, 2003 | 05:23 PM
XLR8NSS's Avatar
Adkoonerstrator
Send it to xlr8nss@bellatlantic.net and I'll send you the link to put in your first post.
Old Oct 9, 2003 | 05:28 PM
Beast96Z's Avatar
[quote]
232/238 XER 112lsa
That's the same cam I got. Hmm, I thought I would be the first. Oh well, at least I get a good look at what it can do. I think you and I will have basically the same set-up, except I will be running the Patriot LS-6 heads. What size injectors did you max out?
Old Oct 9, 2003 | 08:54 PM
Ragtop 99's Avatar
Wow.
Assuming you continue to peak around 7200 do you plan to shift up around 7500? Hope your bottom end is in good shape; sounds like you've got the valvetrain covered.
How much gear are you running?
Old Oct 9, 2003 | 09:12 PM
offaxis's Avatar
Hey phil
Great #`s
What sorings did you have before whne you had all that valve float?
Jeremy
offaxis's Avatar
Hey phil
Great #`s
What springs did you have before when you had all that valve float?
Jeremy
Old Oct 9, 2003 | 09:16 PM
99 Black Bird T/A's Avatar
Great numbers! Congradulations.
What lifters are you running with that cam?
Old Oct 10, 2003 | 12:13 AM
7 Second Club
Beast96z,
SMALL 26.6 99 injectors.
Ragtop99,
I was hoping the cam would peak at 6700 to shift at 7k but it doesnt look like that is goign to happen. The bottom end is forged and should spin to 7k easy.
Offaxis,
Comp Cams 987 springs and they were fine until I went to the big XER cam. They worked fine with a 230/230 XE.
99blackbird TA,
Comp R lifters
I just did all of the final checks, if weather holds out I'll be heading off to the track tomorrow for some shakedown passes. Looking for some 10.20s - 10.60s @ 136-138.
Phillip
