squeeking on decellerating
I burnt the clutch up pretty bad the other week and noticed power loss later that night.
Since i have replaced the air and fuel filters/ plugs and wires. Checked the codes and only codes that i have are for the air.
I have a light metallic squeeking coming from the drivers side rear valve cover area. only at decellerating though that i can hear. And only audible enough to hear when not moving and free reving.
There is a slight manifold to cat exhaust leak.
I have lost about 15 lbs of oil pressure since also. Now at a warm idle it has about 25 to 35lbs before it held atleast 45lbs Oil was recently changed and is good yet. Mobil synthetic 5w30 Suv / Truch and Heavy Duty blend.
Ill post a video in a few minutes when i get back out to it
any help will be appreciated
thanks ken
Pull the valve covers and have a look and if you have duals inspect the inner spring carefully. UOA may also give you a clue and blackstone labs usually has a turn around in a week or so
It doesn't sound like the last bearing I spun but anything is possible
It is not cold OP that matters but what it is at operating temps.
