gasket reuse
Old Feb 13, 2009 | 01:21 PM
forcd ind's Avatar
Default gasket reuse
are the pan, valley, and end gaskets considered reusable, and maybe the intakes? i have reused the valleys before, just curious if there considered reusable-thanks
Old Feb 13, 2009 | 02:23 PM
ss.slp.ls1's Avatar
I would be fine reusing the valley gaskets, intake gaskets, and the MLS header gaskets. Anything else I would buy new.
Old Feb 13, 2009 | 06:17 PM
Mssingkid's Avatar
Depending on how old the car is I would replace the intake gaskets. I re-used mine after a heads and cam install and i ran into a huge vacuum leak. Seems the old gaskets didn't seal on the new heads as well as i hoped. Replaced them and i was golden.
Old Feb 13, 2009 | 06:48 PM
Randy WS6's Avatar
I reuse the oil pan, valley cover, rear cover, timming chain cover , water pump , valve cover gaskets, Replace the front crank seal, rear main seal, and intake gaskets, head gaskets
Old Feb 13, 2009 | 09:12 PM
got-a-ls1's Avatar
yea gm designed most of these gasket to be reusable from what ive researched... i had to drop the oil pan to change my timing chain and have had no problems with the oil pan leaking...
i did replace the timing cover gaskets, intake, water pump and valve cover gaskets just because i had them. I wouldnt hesitate to reuse the old ones though as long as they're not too old or look deformed.
always replace head gaskets... if you have the cometic head gaskets ive heard people reusing them without issues but i dont think id chance that one.
