Head gasket question
Old Feb 14, 2009 | 06:20 AM
Erikz 28's Avatar
Default Head gasket question
Have oil in my coolant... misfire on #7. Bad head gasket I believe. My question: If I do both head gaskets and change my oil and coolant, will that make everything ok again???
Old Feb 14, 2009 | 06:55 AM
Reckless's Avatar
Super Moderator
From what you say, it sounds like you have a blown head gasket, or worse. If you have coolant in the oil, then there are chances you will have issues with the bearings, but not for certain. Best bet is to change the head gaskets and see what you find. You could have broken a piston as this happens on cylinder 7 more than any other.
Old Feb 14, 2009 | 08:31 AM
Erikz 28's Avatar
thanks man... any way of narrowing it down?
just keeps throwing PO307 and codes for bad o2's... it doesnt feel like too much power has been lost
