PRC vs Patriot Extremes
Old Feb 14, 2009 | 07:58 AM
dubrado's Avatar
Default PRC vs Patriot Extremes
which to go for when it comes to reliability and longevity?
Old Feb 14, 2009 | 08:00 AM
C-Sicz's Avatar
I went with the Patriot Extremes. Build is relatively new, but you can beat the price. So far so good.
Old Feb 14, 2009 | 09:06 AM
DrkPhx's Avatar
What are the details of your build and what are your goals?
Old Feb 14, 2009 | 09:20 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The springs are built by the same manufacturer. The PRC components are carefully built here in the U.S.A. under careful tollerences. That's the reason you'll always see the PRC install heights be very consistant while other brands have huge variances in install height. The install height is very important especially when your looking at bigger lift applications like the Torquer 3, MS4 & Tsunami camshafts...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 14, 2009 | 09:04 PM
coanan's Avatar
How would you compare the Comp 26921 to them?
