Possible problem (maybe head gasket?)
Old Feb 15, 2009 | 04:51 PM
MonochromeSS's Avatar
Default Possible problem (maybe head gasket?)
Alright, I've got a bit a problem... maybe.
The car is in storage and has been since late November. As I've done since I've owned the car is I start it about once a month, get it up to operating temp give it a couple revs let it sit a bit and shut it down.
Today i started it and it took a little more persuasion than normal to start. A few turns and a pretty damn loud pop. Sounded like it came from the passenger side. Idle surges a bit, but it always has somewhat, and settles down, seems like it runs ok. I chalked it up to getting a bit to much gas in the motor before it turned over.
I even turned it off and started it back up again a couple times and after that started just fine. Ran it till the water stopped coming out of the exhaust.
If it was just the pop i probably wouldn't be making this post but after i shut it down a could hear a gurgling noise that sounded like it may have been coming from the passenger side head area, hard to tell though. I checked the coolant overflow tank and it was showing a bit low, lower than it should be. Is that the issue, just low coolant?
This motor was built last spring and the heads are o-ringed with copper head gaskets that are made to accept the o-ring.
What do you guys think?
Thanks.
Old Feb 15, 2009 | 05:09 PM
AutomagicLS1's Avatar
Could it have backfired? The water coming out of the exhaust is probably condensation mine does it when it sits for a few days especially when its cold out. If it was blowing coolant you would have a pretty good idea. You will smell somthing that almost smells like syrup. Drain the oil see if theres any water in it.
Old Feb 15, 2009 | 05:10 PM
Oh and the oil looked clean, not cloudy or anything, didnt drain it just pulled the dipstick out a couple of times. That is my hope for not leaking coolant into the engine.
I wasnt really worried about the water. I'ts always spat alot of water. And it was water and just water from what i could tell.
Old Feb 16, 2009 | 07:11 AM
ttt, Any ideas?
