More cam help
Old Feb 16, 2009 | 08:11 PM
GreenBlood's Avatar
Default More cam help
So by summer, my car will be full boltons, and I already have a built Trans. I'm trying to decide on what size stall to get, either a 3800 or 4000. Based on those two options, what size cams would you recommend? I'm looking at PRC stage 2.5 heads, or the TFS 220s, depending on my funds. I don't want a giant donkey dick cam, so I was looking into cams like the VRX5 and smaller. Would that work with a stall that size? The trans is built to handle 600+rwhp, and I'll be spraying 100-150 shot. What are some suggestions, either off the shelf or custom? I need this to inform my trans guy because he will build my stall according to how much spray and what size cam. Thanks
Old Feb 16, 2009 | 08:22 PM
WYATT318MOPAR's Avatar
if you really planning on spray get the smaller stall 3600-3800 most people seem to go really loose. Then have to restall or replace later on due to blow through on the spray. I have a 3700 and will find out how it does in about a month
Old Feb 16, 2009 | 08:30 PM
GreenBlood's Avatar
yea, i heard smaller stalls usually end up flashing higher when not on a bottle. doesnt the yank pye 3400 actually flash at like 4k?
Old Feb 16, 2009 | 08:32 PM
InsaneDomestics's Avatar
I would say the 3800 would be plenty if not to much....I would go with the TFS heads (TFS-3060T001-C01) and there cam (TFS-30602003) it has 228/230 .585/.585. with that setup, depending on your other bolt-ons you should get around 515+.......Add your 100-150 shot and you can get 600+ pretty easy. Hope that helps
Old Feb 16, 2009 | 08:41 PM
GreenBlood's Avatar
thanks
Old Feb 17, 2009 | 01:15 AM
GreenBlood's Avatar
bump...
Old Feb 17, 2009 | 02:54 AM
00MaroonZ28's Avatar
A 3500 should work fine for that set-up.
