What cam won't set a misfire code??
Old Oct 12, 2003 | 12:49 AM
LS198Z's Avatar
Default What cam won't set a misfire code??
What's the biggest cam that won't set a misfire code with a stock tune?
Thanks
Old Oct 12, 2003 | 10:49 AM
wrencher's Avatar
wrencher
Default Re: What cam won't set a misfire code??
I'm thinking the 222 maybe 224 range is about the max.
But if you want the max out of the cam you need tuning.
If your gonna get it tuned w/edit might as well deal with the missfire DTC in the PCM.
But then you can go with a bigger cam....
Maybe what I'm tring to say is look at the big picture & what you want out of the car.
If you do internal engine modd's your gonna need tuning.(to get the most of it)
So you might as well go with the combo that will achieve your goals & plan accordinly.
Old Oct 12, 2003 | 12:30 PM
offaxis's Avatar
i had the tr 220 on a 114 and that threw misfire codes. I think the z06 cam wont throw codes with the stock tune.
Old Oct 12, 2003 | 01:47 PM
strokedls1's Avatar
ls6 is the only one that won't set the p300 code. Not really worth the effort of a cam change for the power you would gain.
Old Oct 12, 2003 | 02:10 PM
lrmneil's Avatar
I have the TR220with a 114 stock tune never a code
Old Oct 12, 2003 | 03:20 PM
YIKESS's Avatar
I have the tr220 112lsa cam for about month now and no misfire codes so far.
A buddy with the TR224 114lsa cam, has throw the code a few times though.
Old Oct 20, 2003 | 11:58 AM
Cal's Avatar
Cal
My TR224 114 has never thrown a misfire code; yet others have with the same cam. Maybe I'm just lucky?
Old Oct 20, 2003 | 01:55 PM
JeremyF's Avatar
LS1TECH Sponsor
I have tuned 100's of cars and the biggest I have seen not set a misfire is a 210/216 or a 03 ZO6 cam. NO matter what you do you need to have it tuned because you will not be reaching the full potential of the cam, in RPM range or with timing you will need to have a bit of stuff adjusted.
Jeremy
 Michael S. Palmer
Old Oct 20, 2003 | 03:04 PM
jrp's Avatar
jrp
SN95 Director
my tr230 threw a code . i say if it dont throw a code its too small
Old Oct 20, 2003 | 03:54 PM
Biochem's Avatar
Does throwing this code affect driving, or does it just set off the SES light come E-check time?
Old Oct 20, 2003 | 07:29 PM
JeremyF's Avatar
LS1TECH Sponsor
If it is an A4 the converter will no lock up, if an M6 I do not know of any issues.
Jeremy
