Flycutting: Safe Solution to my problem? **HELP!**
Company A sold me a set of camshaft specs based on data I provided about my setup (CR, head flow, etc.). From these specs, I purchased a custom grind from Comp that came out as an XE-R 226/230 .600/.601 110 + 4. Company A guaranteed me that I would have no P to V issues
because, "the piston will be 2/3s of the way down the bore when the valve hits max lift." Installer B, who currently has my car, says that there's no way that this cam will work with my heads (MTI SII LS6 milled .030). Installer B has a very good reputation and I don't question his assessment. Anyway, my options are to scrap the cam and buy another one ($400 lost + $400 for a new one) or to flycut the stock pistons. Is flycutting a safe option? Those who have done it on stock LS1 pistons: any problems? FWIW, Installer B doesn't usually recommend flycutting cast pistons, but said many have done it successfully! Whew...sorry for long post, but need help!
..one of the sponsors rents a special head that has the valve seats removed.....you use it with the Isky flycutters and the short block in the car...
...Diamond piston guy said it does not mess the motor balance up because little material is take off....
