head choice
Old Feb 19, 2009 | 03:28 AM
ms4z28's Avatar
Default head choice
I'm trying to decide on was heads I want for my z28 233/239 113lsa slp x pipe ls6 intake and ported tb
I'm thinking 59cc either prc 215 prc 2.5 or some ported ls6 head and I'm thinking of a ported fast 92/95
But I'm not sure price does play a factor but I want to be as close to 500 n/a as I can
And if there are any recomendations on another head I will be more than happy to hear them thank you... And the car made 425 on a mustang 439 in 4wd mode
Old Feb 19, 2009 | 06:40 AM
cws T/A's Avatar
Go with the PRC 215cc .. http://www.texas-speed.com/shop/item...d=993&catid=20
Old Feb 19, 2009 | 08:35 AM
vsocks1's Avatar
Call TEA and look at some options with CNC TFS 215's!
Old Feb 19, 2009 | 08:52 AM
'02 WS6's Avatar
x2 on the PRC 215's those have been throwing out some pretty big #s with the right cam choices
Old Feb 19, 2009 | 09:22 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The PRC 215 has the best potential for getting you to the power your looking for. We've had 4-5 cars goes 485+rwhp with camshafts Torquer & larger using the 215 heads & ported fast intake. You can definately get to 500rwhp with the proper mods & a healthy stock short-block! The PRC 215 will allow you smaller chambers without a need for cutting your pistons
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Feb 19, 2009 | 12:47 PM
ms4z28's Avatar
Ok thank you and does any one no about 58 or 57cc will I run into any problems with clearence and can I still use 91 octane?
Old Feb 19, 2009 | 12:51 PM
ms4z28's Avatar
And if a spray the car will it be the same as if I do now just more hp?
