ms4 with 5.3 heads?
Im getting the heads for really cheap (low mileage) and was planing on having them ported alittle. Ill be doing lifters, oil pump, timing chain and full valvetrain when i pull the stock heads.
im on a budget, wasnt planning on heads and cam just a cam, but i bent a pushrod and messed up the driver side head.
should i just look for a set of 243's? would those be better for that cam?
thanks in advance
I wasnt shure if the valves were much different in size then a set of ported 5.3's.
So i guess ill be loking for a set of 243's.
thanks to everyone
