C5R timing chain sprokets
Old Feb 19, 2009 | 08:26 PM
KsMySS's Avatar
Default C5R timing chain sprokets
Whats everyone using for sprockets with a C5R chain? I used to be using a set from a roll master single timing set with a LS2 chain. But those are pretty worn and I'd rather get some new ones. Not sure if you can buy just the sprockets out of roll masters timing set or not.
Old Feb 19, 2009 | 08:35 PM
themack56's Avatar
I think they use the stock pcs.
Old Feb 19, 2009 | 09:47 PM
405HP_Z06's Avatar
The stock timing gears are more than adequate and readily available.
Old Feb 20, 2009 | 06:23 AM
vettenuts's Avatar
Or Cloyes if you want to degree the cam. Cloyes makes the OEM so their parts will work also. I wouldn't use anything but a Cloyes built part with that chain.
