MS3 Nitrous: what heads?
Old Feb 20, 2009 | 01:35 PM
kilgore's Avatar
Default MS3 Nitrous: what heads?
my mods are as seen im my sig. i am wondering if i even need to change out my heads yet or if i do what set up to go with? i was looking at a set off a 99 vette that run at 10.6 1 compression but is that to much? or will my stock heads be just fine?
Old Feb 20, 2009 | 03:18 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I am running the PRC 5.3 heads with the MS3. Had a TNT F2 kit jetted for a 150 then switched to a carb setup with a 125 plate
Old Feb 20, 2009 | 11:03 PM
PowerShift408's Avatar
You'll be just fine. Let her eat!
