Big Cam Vaccum Issues??
Old Feb 22, 2009 | 02:37 PM
HALF-BREED's Avatar
Default Big Cam Vaccum Issues??
Has anyone had any issues with building proper vaccum with there big cam setups( say .600" and bigger)? If so what were the issues and were you able to resolve these issues?
Old Feb 22, 2009 | 03:24 PM
slothy's Avatar
i had a ms4 and he was able to tune it fine, once in a great while it would wanna hunt for idle.
Old Feb 22, 2009 | 03:28 PM
gsxr1k2's Avatar
i seem to have some issues with it.
Old Feb 22, 2009 | 03:35 PM
SS4Luck's Avatar
my breaks are a little soft down low. other than that i have no problems with vacuum
Old Feb 22, 2009 | 03:59 PM
SOMbitch's Avatar
It is duration not lift that that causes vacuum issues. Having said that even a large cam like an MS4 drives fine because most set idle in the 900-950rpm range so it ends up making up for most of the vacuum loss.
Old Feb 27, 2009 | 02:48 PM
HALF-BREED's Avatar
So would that be the larger the duration the more likely you are to have vaccum issues? And at what range would you start to see these issues?
Sorry guys but im trying to learn.
