How do you get to 750rwhp?
Col, I'm not sure what BeaSSt and Mikey do on a chassis dyno.
I'm telling you folks from experience, $30K will not get you 750 or even 650 RWHP NA with a Gen III engine after parts and labor...and that's not even counting the drivetrain upgrades that are needed.
The graph on this one is weird - Peak FWHP is 725 at 7,500rpm while torque is only 510....
...So if this motor is 725HP at the flywheel, what do you estimate it would make at the wheels? 725FWHP x .85 = 615RWHP????
Robert, I won't claim that I know exactly how to determine RWHP from FWHP but it would make sense to me that the faster you're spinning the weight the more power will be lost to inertia and friction.
I would think an 8000 RPM engine making 725 at the flywheel would be about 580-590 RWHP through an automatic. Some people might not agree that that much power would be lost but the inertial loses involved in accelerating a drivetrain that quickly are great, IMO.
Suzuki Hayabusa, $10,000
Sounds like a bargin to me!
he drives it alot and its very drivable on the street.
Queso, I can tell you from some very brutal experience that you are not going to have nearly enough money to get there. Especially if you are not going to upgrade the transmission or rear end. You might as well add those to your list right now. If you plan on never racing it at the track your parts will survive a little longer. It's inevitable that they are going to break, again and again.
You could buy the ARE motor from the Z, it's pretty close to your budget. I'm sure they would even convert it over to a NA setup and you would do well. Not going to say it will be very streetable yet even street legal though.
Don't forget all the little **** it will take though. Ever take a look at the cost of a big fuel pump and some Aeroquip fittings for the fuel system that you'll have to run?
If I were to spend the money on a true street car I definitely would consider a forged bottom end 346 with a forced induction setup. You can get to your numbers easier. Your neighbors won't hate you when you fire the car up at all hours of the night. And it can be done well within your price range.
Could you see if you can find that post for me? Thanks.
Like you said, Larry's car was not dynoed on a Dynojet. I'm NOT saying that it won't put down 600 RWHP on a dynojet. I don't know, but I kinda doubt it.
The original post
