quick help. Doing a valve spring swap
Old Oct 14, 2003 | 09:23 AM
HumpinSS's Avatar
Default quick help. Doing a valve spring swap
what terminals do i need to use to bump the engine over using a push button starter switch
Old Oct 14, 2003 | 05:24 PM
Ireland31's Avatar
Default Re: quick help. Doing a valve spring swap
Its not necessary to turn the motor over unless there is a reason you'd like to do it to change the valve springs.
Old Oct 14, 2003 | 05:49 PM
HumpinSS's Avatar
The title said such. I finally got it at around 12:00 pm.
Old Oct 14, 2003 | 09:48 PM
Ireland31's Avatar
You didnt understand my post correctly, I know you are changing valve springs, you dont need to turn the motor over to do them.
Old Oct 14, 2003 | 09:55 PM
jmX's Avatar
jmX
Why are you using a remote starter? You can just put a wrench on the crankshaft bolt and turn it by hand.
Old Oct 15, 2003 | 08:16 AM
HumpinSS's Avatar
I had to turn the motor over to make sure the valves didnt fall into the bore incase the piston was at BDC
Old Oct 15, 2003 | 08:17 AM
HumpinSS's Avatar
I didnt have anyone to help me find split overlap and didnt want to chance dropping a valve.
