Reusing valve cover gaskets
Old Feb 27, 2009 | 11:06 AM
Intercooler2's Avatar
Default Reusing valve cover gaskets
Doing valve springs this weekend so was wondering if the gaskets will come off in one piece and can be reused? Or should I just buy some just in case?
Old Feb 27, 2009 | 11:08 AM
1sick'98WS6's Avatar
They are reusable, and will most likely come off in one piece unless someone damaged them before.
Old Feb 27, 2009 | 11:09 AM
vettenuts's Avatar
They are usually OK unless a lot of miles so they have dried out. Worse case would be small leak that would require replacement later.
99blancoSS's Avatar
They are rubber and more like an o-ring and should be re-usable. They sit in a groove, you'll see. Just dont pull them out of the groove
Old Feb 27, 2009 | 11:12 AM
Thanks for the info! I can't wait to get the springs and rockers on. Should pick up a little.
Old Feb 27, 2009 | 08:31 PM
rumblebox's Avatar
i've had mine off several times without replacing. still no leaks.
Old Feb 27, 2009 | 11:15 PM
nemss1's Avatar
had my valve covers off to paint and even pulled the gasket out of the groove. i made sure to rub the gasket down with oil as i was removing the gasket. no probs here
Old Mar 1, 2009 | 02:32 AM
eallanboggs's Avatar
If they don't pop out of the groove while they are off you can just put the covers back without changing them. If they pop out you can't get them back in because they swell up. It's best to have a set on hand just in case.
Old Mar 1, 2009 | 11:27 AM
1998Z28LOADED's Avatar
Mine were half in half out when they came off and the went back in like they were brand new, 100k+ car.
Old Mar 1, 2009 | 11:57 AM
99blancoSS's Avatar
Like sticking a worm through a washer..
