Crank pulley bolt
Old Mar 2, 2009 | 06:29 PM
01pewterSS's Avatar
Default Crank pulley bolt
Is there a special way to take off crank pulley bolt... i have the GM bolt in now... doing a cam swap and trying to take if off... is it like normal bolt right to tighten left to loosen...
any suggestions?
Old Mar 2, 2009 | 06:44 PM
RyderTA's Avatar
Is it spinning on you? Pull off the passenger side plastic plate by the starter and expose the flywheel so you can put a screwdriver through it to wedge it. Then just get a big socket and wrench and a cheater bar and go to town. They are normal threads btw.
Old Mar 2, 2009 | 06:45 PM
Ericbigmac83's Avatar
biiig breaker bar
Old Mar 2, 2009 | 06:48 PM
RyderTA's Avatar
Oh and if you use a 15/16" socket (I think) it fit's almost perfect against the crank to push on with your puller.
Old Mar 2, 2009 | 06:53 PM
04gtoBMXracer's Avatar
Its a 24mm. If your car is a six speed put it in fourth gear. Ls1howto.com
Old Mar 2, 2009 | 07:50 PM
DaddySS's Avatar
And don't forget to get a new bolt, it's a one use only piece. And do not use a bolt to pull the pulley back on - use a threaded rod and nut and washers - do a search on here on crank thread nightmares from using a bolt.
Old Mar 2, 2009 | 07:51 PM
Zitty'sZ's Avatar
Or use a impact gun for the easiest and quickest way if you have one .
Old Mar 2, 2009 | 07:56 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
stick a peice of pipe inbetween and pulley and the oil pan. wedge it in there.... big breaker bar! be careful but itll work... atleast it did for me!
 Michael S. Palmer
Old Mar 2, 2009 | 08:02 PM
blkbird's Avatar
Ive done both with a impact gun, taking it easy of course, and with a breaker bar and brute strength...
Old Mar 2, 2009 | 08:11 PM
got-a-ls1's Avatar
your gonna need a GOOD high torque impact and GOOD compressor. Your standard impacts arnt gonna be even close to knocking that bolt out.. i tried with a snap on impact on a 30 gallon compressor @110 psi lol (kinda small compressor for a impact but 20 psi over max rating lol) and a electric dewalt. they didnt do **** haha...
Old Mar 2, 2009 | 08:55 PM
tording99Z28's Avatar
Big breaker bar here always worked fine. Impact gun would sure be easier though.
Old Mar 4, 2009 | 05:34 PM
01pewterSS's Avatar
thanks for the suggestion... we finally took it off.. we had to use a 1 inch impact off my neighbors service truck... Now i just got to supply the beer for our tuesday nite poker game ... thanks again
Old Mar 4, 2009 | 08:39 PM
'91firebirdformula's Avatar
does anyone recommend any certain way to get the bolt off, while putting the least amount of stress on it? just wondering if there were any tricks? no impact? i dont want to break mine.
Old Mar 4, 2009 | 08:41 PM
just use a breaker bar man. its not too hard. im not a big dude and is cake for me.
