Setting Rev limiter
Just what to know where I should have it set. The cam that im going to put in is a 228/228 .588/.588. 122LSA I got it and the cmotorsport kit. Can I or do I need to rev this thing up to 7000rpm?
I think that after you dyno tune your new cam you should set the limiter a little after your peak. You should have some idea of what it will be or did you buy the cam w/o researching it?
