Cam install
Old Oct 16, 2003 | 12:42 PM
BYOFICR's Avatar
Default Cam install
I have read install instructions and it says I need a longer crank bolt. Can someone explain and also give me the specs on the bolt. I havent figured out what size I needed. Any help is appreciated, thanks
Old Oct 16, 2003 | 12:53 PM
TaTommyWS6's Avatar
Default Re: Cam install
I bought a longer one for my cam install but I had to go a "metric" machine shop. It is not a size you can pick up from a Home Depot. Your best bet is, take your new crank bolt and bring it with you to have it sized up. Get it about an inch longer.
Some people tap their pulley on a bit to get it started, than use the standard size bolt to pull it in, but it could lead to stripping problems as you can see from a nearby thread...
Tommy
Old Oct 16, 2003 | 01:10 PM
jrp's Avatar
jrp
SN95 Director
just order the basic cam and gasket kit from TSP, has the following, its 35 bucks.
Basic Camshaft Bolt & Gasket Kit
Includes GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets, GM Harmonic Balancer Bolt
Old Oct 16, 2003 | 02:39 PM
BYOFICR's Avatar
I already have the gaskets and stuff, all I need is the longer bolt. I have a stock on too
Old Oct 16, 2003 | 02:40 PM
BriGuy's Avatar
I just finished an install yesterday and what I used was a 5" long bolt 16mm with a 2.0 thread pitch. And yes you have to go to a specialty store to get one. But it makes the job a lot easier!!!
Old Oct 16, 2003 | 02:55 PM
jmX's Avatar
jmX
16mm 2.0 pitch as said above, it'll usually have a 24mm head too (at least all the ones I've seen).
You need 120mm long, and 2-3 washers. I will put a picture up tonight on the site along with the specs
