Crank rotation
Old Mar 6, 2009 | 06:16 PM
Legman's Avatar
Default Crank rotation
Looking for some clarifacation...
With #1 at TDC, rotating the crank clockwise, looking at the front, the exhaust valve opens 1st when moving off TDC. I'm trying to make sure I'm on #1 and not #6.
I'm making sure I'm on cam base circle ...to set valve wipe and pushrod length..
Thanks
Old Mar 6, 2009 | 06:31 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
it does not matter about what is where as long as the cam is on the base cirlce. the easiest way is on the compression stroke both valves will be closed. you are confusing timing with trying to check pushrods i think
