Melling 10296 Install ?
Old Mar 7, 2009 | 07:58 PM
skytower31's Avatar
Default Melling 10296 Install ?
I'm doing my cam swap right now and I'm having a hell of a time getting my Melling pump onto the crank snout. Stock one slides on with little to no effort. It seems like the opening for the snout is too small. I even tried sliding it on backwards to see if it would even fit over the snout, no go.
Any thoughts?
Thanks.
Old Mar 7, 2009 | 09:53 PM
cellulis44's Avatar
just keep fiddling.. it'll slide on.. the gerator teeth on the melling are brand new and will be a little tighter...
Old Mar 8, 2009 | 01:00 AM
skytower31's Avatar
And I should use the green oring correct?
