HELP me get this ARP crank bolt out!!!
Old Mar 10, 2009 | 10:05 PM
Deerhunter-Z28's Avatar
I bought a 3/4 breaker bar/socket. Good news is the bolt came out. Bad news is there was a chunk of thread that came out with the bolt! I think I'm fucked.
Old Mar 11, 2009 | 04:54 AM
vettenuts's Avatar
See your other thread.
Old Mar 11, 2009 | 02:59 PM
XtraCajunSS's Avatar
Originally Posted by CamaroFan71
Hey Shane how have things been at the shop? Im the one who came in and talked to you for a while after I bought the Prothane torque arm mount. Havent gotten my car above 14mpg yet, but it also had a huge intake leak along with the clogged cats.
A dead blow socket smacked real hard with a hammer, then a 1" breaker bar with an impact socket on it also may help.
Things have been great here... I have a couple of badass cars we are about to finish so I have been out in the shop a lot, which makes me very happy!
Old Mar 11, 2009 | 04:31 PM
2000Hawk's Avatar
I know I had a hard time getting my stocker off during a cam swap. I grabbed my impact gun and hit it a bunch of times to which it eventually came loose. Then it's an ARP bolt so I'm not sure if it will work, but anything to get that f*cker out.
-Joel
Old Mar 11, 2009 | 04:50 PM
CamaroFan71's Avatar
I wish I had the spare time to do some part time work for you guys or something on the weekends. I cant get enough time around cars. Keep me in mind if you hear of any good deals on some 243's please.
Old Jun 8, 2009 | 09:14 AM
LS1crazy01's Avatar
So what ever happend then with this? Mine is still on but I am gonna try to pull it out again shortly.
Old Jun 8, 2009 | 09:56 AM
ABQ99TA's Avatar
Originally Posted by LS1crazy01
I am in the same boat as you actually. I put my new pulley in last year and it said to put it on and use the stock bolt to press it on the snout and then back it out and use the new one and tourqe to spec. Well I was never able to get it out and just said F**k it and just tourqed it to spec and left it. I am gonna eventually have to get it out when I do my cam though so I hope somone has an answer for you. Good luck buddy.
You might be fu**ed if you left the old bolt in. If you have had it in for that long and it was the old bolt. The stock TTY bolts suck and it might break when you try to get it out. Someone did something similar to mine and it broke when I tried to remove it. Good luck hope you don't have to drill it out, it sucks bad.
Old Jun 8, 2009 | 03:45 PM
1Loudz28's Avatar
i just removed mine with a huge break bar and pipe extension. tore up the first 4 threads but my friend was able to chase them and we got a new GM bolt in. problem solved.
