Tips for cleaning out head bolt holes...?
Old Mar 17, 2009 | 11:24 PM
c0ncEpT's Avatar
Next time you take the heads off just grab a wet/dry vac and when you take the water pump off just suck that baby dry.
You wont have to clean a single bolt hole again other than just testing a few as a piece of mind!
Old Mar 18, 2009 | 08:01 AM
NeXuS's Avatar
+1000 When i did my passenger side i didnt pull the water pump... after 4 hours of cleaning.. (partially due to my fault. Paper towel breaking off and getting stuck in the bolt hole, Twice!) I got it all clean.. the Drivers side i pulled the Pump, Sucked all the water out and it only took me 15 mins to check the holes and very little water in just a few... So yea pull that sucker if you can and suck all the water out...
Old Mar 18, 2009 | 12:00 PM
m6speed's Avatar
Originally Posted by Grimes
shop vac with a straw duct taped to the end of it....will go right down the hole, lol. that and then let it sit with towels rolled up in them.
+1 works everytime
Old Mar 19, 2009 | 02:40 PM
382ssz28's Avatar
Talking ARP Thread Chaser
Originally Posted by Soul TKR
what tool are you talking about?
I have it at my shop and haven't been in the area. I thought any of the engine builders would chime in and get a part #. I can get it in a couple of days if noone gets it first. Basically, if anyone is going to work on these engines, to properly clean the threads use this thread chaser on every hole-then blow out the hole with compressed air-then use the plastic extender on some brake clean to blow in some brake cleaner-then blow out with comp air. This will leave the hole perfectly clean of debri and liquid, and dry. Improvising is OK, but the right tool for the job is a guarantee!
Old Mar 19, 2009 | 09:12 PM
cyacops's Avatar
drain your block first and you won't have to clean any bolt holes just blow them out quickly with air
Old Dec 18, 2010 | 11:15 PM
LSjim's Avatar
if you need to get fluid out go to pep boys and buy the air gun they have that hooks up to your compresser its 6.99 and hooks up to a fish aration tube perfectly and sprey that in the bolt hole first then use some parts cleaner it will make the bolt hole perfectly dont use regular caned air the pressure isnt enough
Old Dec 19, 2010 | 01:56 AM
stangtrader's Avatar
All mentioned ways work I personaly used a can of dust off rags brakeclean and thread chaser worked great
Old Dec 19, 2010 | 08:49 AM
LS1-450's Avatar
I shop vac 'em, then blow 'em out w/ shop air, then check for dryness w/ paper towel on a shish kabob stick.
