BEST HEAD GASKET
Old Oct 19, 2003 | 02:57 PM
Mater's Avatar
Default BEST HEAD GASKET
for head swap on ls1& 6.0 cast block??
i have two diff. swaps going on
thanks guys
Old Oct 19, 2003 | 11:39 PM
Quik's Avatar
Default Re: BEST HEAD GASKET
how about a mister gasket
Old Oct 19, 2003 | 11:44 PM
Spinmonster's Avatar
Cometic multi-layer steel comes in various thicknesses so you can get way more strength and up your CR to boot. Each full point in CR is 14hp
Old Oct 20, 2003 | 09:27 AM
Mater's Avatar
were would i get them?
Old Oct 20, 2003 | 09:43 AM
2001 Pewter WS6's Avatar
Restricted User
I have had very good luck with GM's.. And they are a lot cheaper as well. Check SDPC ---->
Old Oct 20, 2003 | 01:57 PM
JeremyF's Avatar
LS1TECH Sponsor
I used cometics until GM came out with the 02-04 HG it is a bit cheap for the quality.
Jeremy Formato
Old Oct 20, 2003 | 02:13 PM
GWTFI's Avatar
Any input on the best gaskets for a 4.030 6.0l iron block?
Old Oct 20, 2003 | 06:51 PM
LiquidSnake's Avatar
Whos selling cometics?
Old Oct 20, 2003 | 11:02 PM
www.cometic.com buy them direct....good to deal with.
Old Oct 20, 2003 | 11:45 PM
Smoke_Ford's Avatar
felpro
Old Oct 21, 2003 | 07:31 AM
BigTex's Avatar
Can you run the felpro 1041 gaskets with heads that are O-ringed?
Old Oct 21, 2003 | 06:25 PM
Thanks Spinmonster
