need help for ticking noise.
hard to explain. i jope some of this makes since.
here is a vid from the beginning before i swapped lifters.
http://videos.streetfire.net/video/t...tap_636916.htm
Assuming it's not a lifter giving you the problem......
One option is to run a good flushing oil through it to clean all the gunk out of it, and then change to a 10w40 or 15wXX oil to see if that quietens it down.
A lot of noisey LS engines are much quieter if you move away from 0w-- and 5w-- oils.
(The Castrol 10w60 has had a lot of success at doing this very thing).
